change item location in table
ychen-4
how can i change item location in table? i would like to change the item 2 to item 3,and change item 3 to 2
thanks
pls reference the blow table .
ldrutel
(To:ychen-4)
If this is a repetition table, You can Fix item
1) Select Repetition table tab
2) Select Fix item and select your repetition table
Now you can fix each item you want to do
3 REPLIES 3
ldrutel
(To:ychen-4)
ychen-4
(To:ychen-4)
thanks the first !
let me try .......
ychen-4
(To:ychen-4)
thanks laurent
I have changed the item location use your solution!
select the repeat table,the system says:Can not fix index due to symbol asm.mbr.cparam
SEQ NO.properties &asm.mbr.cparam.seq_no.  so i need modify this SEQ NO properties(delete "&" temporary)
after change the SEQ NO . i can select the repeat table fix the item .
