conversion of unigraphics file to pro-e
  • July 30, 2004
  • 2 replies
  • 1116 views
I would like some help to convert all our unigraphics files to pro-e.
We no longer have use of the unigraphics software and need to convert
them.
If anyone has any feedback on what software to use or what kind of success
you may have had it would be much appreciated.
Mike
    Same problem here.
    We are working together with a mouldmaker,using Unigraphics.
    How can we open the Unigrapihics files in Pro E?
    In Reply to:
    them.
    Mike
    PTC has a UG/NX module that allows you to open a UG/NX file in Wildfire,
    HOWEVER it requires a seat of UG/NX to operate.
    The module is also expensive, ~10K less your discount.
    UG/NX however has a module that can open Pro/E Wildfire files and does
    not require Pro/E Wildfire on the workstation.
    Pricing is similar.
    So, if you only have Pro/E, then you need to get the vendor/supplier to
    provide you a STEP or IGES file instead of a native one.
    The alternative for a one off translation is to have a good friend in
    the CAD community who can do it for you. Smiley Happy
    Ben Loosli
    Sr IS Technologist
    Engineering Automation Systems
    L-3 Communications/Integrated Systems
    Waco, TX 76715
    254-867-4069
