enabling model tree seperate dialog box
  • July 7, 2016
  • 4 replies
  • 4478 views
can anyone let me how to enable the model tree seperate dialog box creo 2.0 ,earlier i use to get this ,now it is disabled.
it  willbe in view-->show-->model tree
    There is a way, but it will close as soon as you make a new feature. Right click the part and click View Changes, and undock Model Tree appears.
    mrd10-MarbleAuthor
    thanks for your reply but i m more concern about how to activate the view-->show-->model tree
    I misunderstood your question, use this button then.
    maybe Model Tree Won't go back into browser
    Silver
    it's very confusing. hopefully I recall this correctly, add these 2 configs..
    www_tree_location=out
    enable_tree_indep =yes
    restart Creo and goto windows settings and then you can set which side, etc
    I'm not sure why I couldn't get it back in, I've done it from time to time if I need a lot of columns. i wouldn't recommend it.
    i would recommend floating the layer tree with.......
    floating_layer_tree=yes
    i've never had a problem reverting that, it requires a restart too.
    mrd10-MarbleAuthor
    hi
    i have added  floating_layer_tree=yes in my config.pro,but still it's not working out
    Set these 3 options in the config.pro
    www_tree_location out
    enable_tree_indep yes
    floating_layer_tree yes
    save your config.pro
    in the file options windows settings, click the box DISPLAY AS SEPARATE WINDOW
    make sure you save those settings also
    close and restart creo
    I have a treetool txt file in my start in directory that seems to affect my modeltree window on my secondary display. I thought I created notes on how to set this up but I can't find them today.
