hole table display of UNC/UNF holes
The description of both tapped and clearance holes shows up the same
when using the hole table ie the default note is "10-32 UNF" How do
you change the display to the full note
ie
10-32 UNF-2b thru
or
10-32 UNF Clearance
Drill (.201)........
WF5 F000
ie
10-32 UNF-2b thru
or
10-32 UNF Clearance
WF5 F000
