how to merge several surfaces one-time with the proe
  • March 7, 2010
  • 10485 views
how to merge several surfaces one-time with the proe.i know ug can easily apply this command.when will the PTC company can solve this question.
    Not sure what version you are using but you can do this starting in WF4. Not sure about WF5.
    Jim_zhao1-VisitorAuthor
    If a surface will be trimmed by the merge, you can only pick two surfaces at a time. So then you need to pick the merge quilt and then the next surface if you want to merge more than two surfaces.
