multiple workpieces
  • April 10, 2014
  • 2 replies
  • 3088 views
we started using more than one workpiece in NC-complete, to program multiple operations in one cam file. but the material removals sometimes cannot handle this correct, but for example after a restart everything is back ok. but the more sequences there are, the more these material removals go in error.
does anyone have any experience with using multiple workpieces?
Greetings,
Arno
    I am talking about Turning operations.
    I am currently working with a file that has 6 reference models and a corresponding 6 workpieces. I set them up in an array. I do them all in the same file because they are all part of the same fixture, and the speeds, feeds, filenaming conventions, etc. are the same for each.
    I space the parts far enough apart that any material removal simulation on one of them does not affect the others. Are your workpieces overlapping so that an operation that should only affect one is cutting into another?
    The price I pay for spacing my parts far enough apart to avoid strange "operation on part 1 cuts part 2" stuff is that when I reset the view scale (or when Creo does it itself), things are pretty small. I also have to have a bunch of coordinate systems, at least one, but usually more for each part.
    Are you also talking about Turning NC sequences? or milling... because mine are all overlapping, with the same Zero point.
    in the meantime I got an answer from PTC and it seems this is not realy supported to get correct material removals in this situation.
    but Material Removals in general is a feature that needs to be enhanced!
    very nice I see op1 in your pic what happens in op2 or more correclty what do the errors look like in your work peices? and are you using automatic material removals or constructed?
