pipe over two planes
- November 20, 2014
- 1 reply
- 1752 views
i've attached a picture, the bottom pipe is on a different plane angled at 10 degrees from the plane the top pipe is on.
I am trying to either create a joint between the two or, better yet, make the two pipes one.
The problem i have is that any joint i try to put on these pipes either does absolutely nothing or creates a strange pipe which would not be able to actually be welded together.
Any help on this would be gratefully received
