pro engineer model to 3ds max
  • May 8, 2009
  • 7373 views
Hello all, I have received pro engineer files from a client that I need to import into 3ds max, can someone point me into the right direction on how to achieve this? I know npower has a translator but there has to be a lesser expensive way? Are there services for this kind of work? Greetings
    I usually export STL files from Pro/E, with a high triangle count for a smooth mesh. Then import into 3ds Max, then use a smooth modifier in MAX on all parts. Imported parts will lie on their backs. Group them together, then rotate 90 degrees upright. Dont know if there is a better way
    thanks for your reply, actualy there is a better way but more expensive, I don't know how many models you have to translate in your job, if it is a lot thatn the plugin pays itself off: http://www.npowersoftware.com/translators/ptProE.htm In my situation it is gonna be rare to import pro engineer models into max so I'm still looking into alternatives, I am gonna investigate what you sugest tnx!
    Fyi I now know there is also okino: http://www.okino.com/conv/order/order.htm?0#basicpricinginfo a lot cheaper than npower pro E solution
