pro engineer model to 3ds max
  • May 8, 2009
  • 7373 views
Hello all, I have received pro engineer files from a client that I need to import into 3ds max, can someone point me into the right direction on how to achieve this? I know npower has a translator but there has to be a lesser expensive way? Are there services for this kind of work? Greetings
    I usually export STL files from Pro/E, with a high triangle count for a smooth mesh. Then import into 3ds Max, then use a smooth modifier in MAX on all parts. Imported parts will lie on their backs. Group them together, then rotate 90 degrees upright. Dont know if there is a better way
    thanks for your reply, actualy there is a better way but more expensive, I don't know how many models you have to translate in your job, if it is a lot thatn the plugin pays itself off: http://www.npowersoftware.com/translators/ptProE.htm In my situation it is gonna be rare to import pro engineer models into max so I'm still looking into alternatives, I am gonna investigate what you sugest tnx!
    On the subject of going from Pro/E to an animation system. I'm trying to find the best route to go from Pro/E to Cinema 4D. I know that Wavefront .OBJ work well, but leave much to be desired with the final mesh. Does anyone know whether it's possible to export a model format which would preserve NURBS data? Or at least a better mesh format than the triangle polygons which are created by the .OBJ??? Thanks.
