rotation of the original pattren
  • April 20, 2014
  • 4674 views
hi,
i draw a turbine ans a fan and a solid parts and i do a pattren for the plate for poth of then then when i tried to rotation of the pattren the original pattren dosent rotate is there any whay that i can rotate the original pattren as u can see in the pictuers is there any one can help me with this thing?????
    Looks like you posted in the wrong subspace of this communitiy. Here is the section dealing with the calculationd program Mathcad and possibly we can't help you.
    Werner Exinger could u please tell me where i can post it so thay can help me with this problem
    thanks alot
    You don't state which program you are using, so I assume its Creo.
    Then this wouldbe the right place: http://communities.ptc.com/community/creo?view=discussions
