save-as with update parent
  • June 6, 2013
  • 5 replies
  • 3120 views
All,
Anyone have a "how to" for:
Workspace save-as with update parent. (How to use the "update parent"
ability?)
WayneF
    20-Turquoise
    June 6, 2013
    On 06/06/13 10:29, wayne falco wrote:
    > All,
    > ability?)
    There is not really very much "how to" for this. Either you select the the parent assembly for
    updating or you don't. The parent assembly needs to be checked out (or a new object) in order to be
    eligible for updating.
    > WayneF
    Randy Jones
    Systems Administrator
    Great Plains Mfg., Inc.
    1525 E North St
    PO Box 5060
    Salina, KS USA 67401
    email: -
    Phone: 785-823-3276
       Fax: 785-667-2695
    wfalco16-PearlAuthor
    I guess I was looking for a decent example on the steps.
    kdirth
    First the item being copied and the parent assembly need to be uploaded or unmodified and the parent assembly needs to be checked out.
    Check the item being copied and select File/Save As
    Update name of copy and select next.
    Check the assembly to replace the item in and select Use Copy.
    Select Finish.
    If the parent assembly is "Struck Through", it is ineligible for some reason.  Hover mouse over red "i" to see reason, then cancel copy, fix issue, and start over.
    A fellow worker uses this when he forgets to include an item in a save
    as. He's not much on documenting how he does it. So - I am reaching.
    The Windchill local client automatically prompts for the substitutions desired as soon as you do a Workspace Save-As to search for/select the target assembly (ies) and the target assembly(ies) need to be in the Workspace and be checked-out.
    I think the lack of a video/all steps is that it is about 50 times more effort to create that tutorial than for you to try it.
    Wassa matta John you scaid o'sumetine, scaid??
    YOU BIG DUMMY
    Wayne Falco?     Wayne Falco?     Wow...Wayne Falco!!
    Hey Dean. How's things?
    Still making little rocks from big rocks. distress.jpgYou know, I am retired but I still have to go to work every day!
