I was just going to delete them all out and put them back in. But I can not figure out a simple way to get the pattern to work. Can draw in 100+ points, but that's a lot of work.
I only have an older version of creo. If you have a version of Solidworks, use that to export a STEP file. Sometimes when I get vendor STEP files, I import it into Solidworks, and that usually automatically fixes it. If not, I use their version of IDD, fix as much as possible, then STEP out to Pro/E. That usually fixes most everything.
