start up error "Xerces Panic Error"
  • January 23, 2010
  • 1787 views
after installing AVG anti-virus software I now get the start up error "Xerces Panic Error. could not load a transcoding service" Pro-E won't start up now. anyone know what that means? Thanks in advance
    I found this, but I don't know if it helps you or not: http://seer.support.veritas.com/docs/267249.htm
    Also, if you do a search on the web using your error message as the search string... a BUNCH of different hits come up. Apparently this is not a unique error.
    7-Bedrock
    January 27, 2010
    Not really help, but we also run AVG and Wildfire 5.0 without that problem. Bruce
