Creo "Reverse Engineering" Tips & Techniques Session Recording (West Coast)
  • January 25, 2022
  • 1941 views
Check out this video on Creo Reverse Engineering from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: January 25, 2022
Webcast Q&A
Question from AnonymousWe have "Shrink Wrapping" feature to align with scanned model?
Answer:  This is what was demonstrated with the "Freestyle" tool.  Depending on the resolution you choose to use, it will "shrinkwrap" more accurately.
Question from AnonymousCan we do the project sketch from the initial file and then create the surfaces?
Answer:  Yes, one method would be the Restyle/Extrusion tool and the project sketch option as demonstrated.
