How to change the system colors in Creo Parametric
  • December 15, 2021
  • 2526 views
In this video, we will learn to
  • customize the system color
  • set background color to display a gradient between two colors
I recently update to Creo 8.0.2. In previuos versions, it was possible to have the edge of the planes of two different color (one for the positive side, one for the negative side).
In Creo 8 now only the surface of the planes is colored (one for positive, one for negative) but not the edge fo the planes. The edge are the same color for both sides.
How can I set this in Creo 8?
Thank you.
@bchen
