How to apply load on small region instead of whole surface in Creo Simulate Live
  • October 12, 2019
  • 4085 views
I want to apply load on particular region only instead of whole surface. I tried lot but able to identify option in Simulate live. Can any one help me on that ?
Note :: In Normal creo simulate, we use surface region
kdirth
The only method I have come up with is to extrude a thin pad in the area wanted.  Should work fine as long as this area is not a critical stress area.
7-Bedrock
October 24, 2019
Extruding a small surface region for defining the area where the load is applied... that is the same I did.
But I can almost not wait for the possibility to apply the load on a small area respectively certain region.
gulag901-VisitorAuthor
I tried with extrude option with less thickness, but simulation live shows more stress on extruded surface due to less thickness.
