11-Garnet
November 28, 2020
Area of inner contour (PRO_CONTOUR_TRAV_INTERNAL)
  • November 28, 2020
  • 2546 views
How to fine the area of inner (PRO_CONTOUR_TRAV_INTERNAL) contour of surface? This inner contour has been created by cut feature.
A possible workaround is to convert a surface to a NURB one with ProSurfaceToNURB(...) , apply the inner contour in question from the original surface with ProSurfaceContourArraySet(...) to the new NURB surface while changing contour traversal flag to external.
HIH.
11-Garnet
December 3, 2020
Thank you for you answer, I'm still working on it, and but because I'm beginer I have a lot of issues with implemetation. Could you provide more information about your idea?
Thanks in advance.
18-Opal
December 3, 2020
I see 2 other options, #1 tessellate the contour and calculate the area, or #2 suppress the cut feature, measure, resume, and do a diff of both areas. The last option is handy if you don‘t need to resume a lot of features, and you don‘t want to calc the area by your own algorithm.
