Automation of PDF Generation process in Creo
Need suggestion on automating PDF generation process in PDM (Creo tool).
Normally PDF file will be generated once CAD file check-in with required modifications. Idea here is to automate PDF generation process once part is check-in. so that one more manual step for generating PDF can be avoided in Creo.
Kindly suggest on
