Cache for me from a client
  • March 4, 2024
  • 2589 views
I work with 3 different clients all using the same version of CREO would there be any way when opening CREO select client and save the cache in a specific folder? today I use this way.
ENV=PTC_WF_ROOT=D:\Cache\%USERNAME%\PTC\ProENGINEER\Wildfire\.wf
Best answer by MartinHanak
in Parametric\bin directory you have to create three .psf files by copying parametric.psf file.
client1.psf
ENV=PTC_WF_ROOT=D:\Cache\%USERNAME%\PTC_WFROOT_Client1
client2.psf
ENV=PTC_WF_ROOT=D:\Cache\%USERNAME%\PTC_WFROOT_Client2
client3.psf
ENV=PTC_WF_ROOT=D:\Cache\%USERNAME%\PTC_WFROOT_Client3
client1.psf
client2.psf
client3.psf
MS_Santos15-MoonstoneAuthor
But when Creo loads it, will it know which client1.psf belongs to each client? If the version is the same?
I am sorry I do not understand your question.
