Can I take screenshots by WebLink?
wshih
6-Contributor
Hi All:
I have custom program by WebLink.
part of steps, user need to take a Creo screenshot.
This idea guide user modeling and configuring.
Then take screenshot, upload and log it.
Thanks for every idea.
YaroslavSin
(To:wshih)
If you need screenshot with model or drawing (working area) - take a look to export to images functionality.
If you need an image a whole Creo with UI, I think, in this case need to use external software and call this by macro.
https://superuser.com/questions/75614/take-a-screen-shot-from-command-line-in-windows
5 REPLIES 5
YaroslavSin
(To:wshih)
wshih
6-Contributor
(To:YaroslavSin)
Hi ysinitsyn:
Thank you for your help.
Yes, I want screenshot with model.
I found a function pfcWindow::ExportRasterImage, is right?
If yes, did you have any idea about pfcRasterImageExportInstruction.
I am not sure how to use it. Did you have any example?
Thank you, again.
Hmm - that function is very vague in the Creo 4 UG for Weblink...
It appears to only export one (1) format...  the Parametric raster output file... which I have no idea what format that is.
I guess you will have to try it and see how it works.
Dave
wshih
6-Contributor
(To:YaroslavSin)
I can take screenshot now.
Thank you everyone  🙂
You could use the CREOSON interface : export_image command to easily write and image of the active Creo session.
This *may* be able to be called from a WebLink page... or you could load a special page for this operation from the CREOSON server.
Only as a suggestion.  I believe there is an example of this in the Playground within the CREOSON distribution.
Dave
