Changing default settings
I'm working with Direct Modeling 64bit 18.1 (M020) and experiencing a frustrating problem.
I need to change Annotation default settings (viewport color, text, dimensions and so on) and am sure that this operation was already made in the past, since a customized set (created with version 17, with only viewport color changed) is present.
Well, something seems wrong, since no change gets saved; nor creating a new style works. I close, start and no change is kept, the new style is not available.
I see that a new lsp style file may be created manually copying an existing one in C:\PTC\Creo Elements\pM318\Setup\SD_GoldTop_pc\annot\2D_Interface\ConfigStyle\ANNOTATION\Default_Settings, anyway no further change will be saved in it. I guess some variable must refer to the wrong path.
Does anybody know this problem and can help me to solve it?
Thank you everybody.
Marco
