Configuring J-Link in Creo 2.0
Hello everyone,
We are currently in the process of evaluating Creo 2.0
One problem that we can not seem to solve is configuring our J-Link application (which runs succesfully in WildFire 5.0) in Creo 2.0
There seems to be something wrong and I hope someone on this forum already has experience with J-Link in Creo 2.0
This is the current configuration which works in WildFire 5.0
- C:\Projects\Shape\Shape.jar is the JAR file to be used by J-Link
- C:\Projects\Shape\Text\shape.txt is the text file used in the application
- Environment Variable "CLASSPATH = C:\Projects\Shape\Shape.jar"
- Protk.dat file located in C:\ptc\proeWildfire 5.0\text
name Shape
startup java
java_app_class Shape
java_app_start start
java_app_stop stop
allow_stop true
delay_start false
text_dir C:\Projects\Shape\text\
revision 0.0
end
This is the configuration which does not work in Creo 2.0
- Protk.dat file located in C:\ptc\Creo 2.0\Common Files\F001\text
name Shape
startup java
java_app_stop stop
allow_stop true
delay_start false
revision 0.0
end
As you can see, the only difference is that we copied the WildFire 5.0 'Protk.dat' file to C:\ptc\Creo 2.0\Common Files\F001\text
If someone has anything to add, please do.
Kind regards...
