Using Creo Parametric 5 as a standalone, is there a way I can customise what details are shown at the top of the screen. Is it driven by parameters?
In the past when we used pro intralink, this would show the revision, version and release level using PDMDB/REV/RL. (see screenshot).
I looked all through the config options but couldn't see anything that controls this display.
Any help welcome!
I did find that if you add the config option 'allow_create_PDM_param=yes', Creo allows you to manually type in reserved parameters PDMRL and PDMREV.
Any value you type in for these parameters then appear in the windows title.
But as far as being able to swap these for other parameters to display in the title it appears to be a no-go (or at least not easy or advised).
Dan.
information displayed in windows title is hardcoded, you cannot configure it.
Hi Martin,
Many thanks for letting me know.
Dan
Dan.
