Drawing table name using protoolkit
  • April 15, 2015
  • 0 replies
  • 803 views
I would like to find out name of the table into the creo drawing file using Protoolkit.
I tried to find out but could not succeed.
Requirement of table name set:
  • I would like to generate BOM table and do Ballooning using toolkit.
  • If I am supposed to do BOM and Balloon simultaneously in one run of application, I can use ID of drawing table (BOM) created by my application for Ballooning.
  • But what will happen is BOM is generated by application and after few days, User may use application to do ballooning using same BOM table
  • In this scenario, I will not be having handler of the created table and hence name (or some specific unique identifier to choose BOM table created by application) is required to do Ballooning.
Feel free to write in case more explanation is required on why I need to set the name of the table.
Any help on this is appreciable!
Thanks and Regards
Ketan
