I am trying to build element tree of pattern table in creo toolkit C++ . I have dimensions stored in a vector. I am facing issue in assigning the first instance.
Is there any sample code to refer for building element tree of pattern table?
What is correct method to set the values in first instance?
Hi @Marcusanthony
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
