Hi
You need to use OTK.
// Header
class helplistener : public uifcDefaultDialogListener {
public:
void OnHelp(uifcDialog_ptr dialog);
void OnClose(uifcDialog_ptr dialog);
// Code
uifcDialogFind(DIALOG_NAME, DIALOG_NAME)->AddActionListener(new helplistener());
uifcDialogFind(DIALOG_NAME, DIALOG_NAME)->SetHasHelpButton(true);
void helplistener::OnHelp(uifcDialog_ptr dialog)
// do what ever you like
If there is no OnHelp Action is the same as if there is no OnClose Action. The Buttons are disabled.
The onHelp Action doesn't override the F1 Button Help Call.
Br,
Eike
