How to Undo the operations created by Object toolkit
  • October 13, 2020
  • 1634 views
I am creating some features using Object toolkit application C++.
But once operations are done, I cant undo them.
Is there anyway with which I can add undo point till the state before I started by application
  1. erase modified model from session
  2. open the model from disk
Hello Martin,
Thank you for your reply.
Your suggestion seems great, but it may not fit my requirement.
As there are multiple operations are done on part, I just want to remove last operation that was done on my part. Just last.
I see a way around with using your suggestion, but Can you please help me with Object Toolkit code/function for the erasing and reopening model.
@RS_9601780 wrote:
Hello Martin,
I am sorry i can't help you I am not software developer.
