How to create Sketch Feature
Hello Friends,
I write a function to create sketch feature , Feature created in feature navigator but 2D Line does not get added in sketch feature , I am sharing the function for your reference . Please resolve the issue.
ProError ProSketchFeature()
ProReference REPDEP_ref2;
ProReference REPDEP_ref1;
ProErrorlist errors;
ProMdl model;
ProModelitem model_item;
ProSelection model_sel;
ProFeature feature;
ProFeatureCreateOptions *opts = 0;
ProElempath path;
ProElempathItem path_items[2];
ProSection section;
ProAsmcomppath comp_path;
ProAsmcomppath *p_comp_path = NULL;
ProValue value;
double width;
double height;
double bite_radius;
double bite_height;
char name[PRO_NAME_SIZE];
ProBoolean alloc;
ProElement sketch_element;
ProElement created_elemtree;
ProElement pro_e_feature_tree;
ProElement pro_e_feature_type;
ProElement pro_e_curve_type;
ProElement pro_e_std_section;
ProElement pro_e_std_sec_method;
ProElement pro_e_std_sec_setup_plane;
ProElement pro_e_std_sec_plane;
ProElement pro_e_sketcher;
ProElement pro_e_std_sec_plane_view_dir;
ProElement pro_e_std_sec_plane_orient_dir;
ProElement pro_e_std_sec_plane_orient_ref;
ProSelection *sketch_refs;
ProName wide_string;
ProError status;
ProValueData value_data;
ProSelection * p_select;
int n_select;
ProBoolean is_interactive = PRO_B_TRUE;
Populating root element PRO_E_FEATURE_TREE
status = ProElementAlloc(PRO_E_FEATURE_TREE, &pro_e_feature_tree);
Populating element PRO_E_FEATURE_TYPE
status = ProElementAlloc(PRO_E_FEATURE_TYPE, &pro_e_feature_type);
status = ProElementIntegerSet(pro_e_feature_type, PRO_FEAT_CURVE);
status = ProElemtreeElementAdd(pro_e_feature_tree, NULL,pro_e_feature_type);
Populating element PRO_E_CURVE_TYPE
status = ProElementAlloc(PRO_E_CURVE_TYPE, &pro_e_curve_type);
status = ProElementIntegerSet(pro_e_curve_type, PRO_CURVE_TYPE_SKETCHED);
status = ProElemtreeElementAdd(pro_e_feature_tree, NULL,pro_e_curve_type);
Populating element PRO_E_STD_SECTION
status = ProElementAlloc(PRO_E_STD_SECTION, &pro_e_std_section);
status = ProElemtreeElementAdd(pro_e_feature_tree, NULL,pro_e_std_section);
-> PRO_E_STD_SEC_SETUP_PLANE
status = ProElementAlloc(PRO_E_STD_SEC_SETUP_PLANE,&pro_e_std_sec_setup_plane);
status = ProElemtreeElementAdd(pro_e_std_section, NULL,pro_e_std_sec_setup_plane);
sketch_refs = (ProSelection *)calloc(2, sizeof(ProSelection));
FeatByName feat_sketch[] = { { "XSEC" } };
ProSolid solid;
status = ProMdlCurrentGet((ProMdl*)&solid);
status = ProUtilFeatsByName(solid, feat_sketch, 1);
status = ProFeatureInit(solid, feat_sketch[0].id, &feature);
status = ProFeatureGeomitemVisit(&feature, PRO_TYPE_UNUSED, ProUtilFeatFirstGeomitemVisit, NULL, (ProAppData*)&model_item);
ProSurface surface;
status = ProGeomitemToSurface((ProGeomitem*)&model_item, &surface);
ProModelitem modelItem;
status = ProModelitemInit(model_item.owner, model_item.id, model_item.type, &modelItem);
int plane_id;
status = ProSurfaceIdGet(surface, &plane_id);
-> PRO_E_STD_SEC_PLANE
ProSelection selection;
status = ProSelectionAlloc(NULL, &modelItem, &selection);
status = ProElementAlloc(PRO_E_STD_SEC_PLANE, &pro_e_std_sec_plane);
status = ProSelectionToReference(selection, &REPDEP_ref1);
status = ProElementReferenceSet(pro_e_std_sec_plane, REPDEP_ref1);
status = ProElemtreeElementAdd(pro_e_std_sec_setup_plane, NULL,pro_e_std_sec_plane);
-> PRO_E_STD_SEC_PLANE_VIEW_DIR
status = ProElementAlloc(PRO_E_STD_SEC_PLANE_VIEW_DIR,&pro_e_std_sec_plane_view_dir);
status = ProElementIntegerSet(pro_e_std_sec_plane_view_dir, PRO_SEC_VIEW_DIR_SIDE_ONE);
status = ProElemtreeElementAdd(pro_e_std_sec_setup_plane, NULL,pro_e_std_sec_plane_view_dir);
-> PRO_E_STD_SEC_PLANE_ORIENT_DIR
status = ProElementAlloc(PRO_E_STD_SEC_PLANE_ORIENT_DIR,&pro_e_std_sec_plane_orient_dir);
status = ProElementIntegerSet(pro_e_std_sec_plane_orient_dir, PRO_SEC_ORIENT_DIR_UP);
status = ProElemtreeElementAdd(pro_e_std_sec_setup_plane, NULL,pro_e_std_sec_plane_orient_dir);
Creating incomplete feature in the current model.
status = ProMdlCurrentGet(&model);
if (status != PRO_TK_NO_ERROR) return (status);
status = ProMdlToModelitem(model, &model_item);
status = ProSelectionAlloc(p_comp_path, &model_item,&model_sel);
status = ProArrayAlloc(1, sizeof(ProFeatureCreateOptions),1, (ProArray*)&opts);
opts[0] = PRO_FEAT_CR_INCOMPLETE_FEAT;
status = ProFeatureWithoptionsCreate(model_sel, pro_e_feature_tree,opts, PRO_REGEN_NO_FLAGS, &feature, &errors);
status = ProArrayFree((ProArray*)&opts);
/* Using the element tree from created feature */
status = ProFeatureElemtreeExtract(&feature, NULL, PRO_FEAT_EXTRACT_NO_OPTS, &created_elemtree);
path_items[0].type = PRO_ELEM_PATH_ITEM_TYPE_ID;
path_items[0].path_item.elem_id = PRO_E_STD_SECTION;
path_items[1].type = PRO_ELEM_PATH_ITEM_TYPE_ID;
path_items[1].path_item.elem_id = PRO_E_SKETCHER;
status = ProElempathAlloc(&path);
status = ProElempathDataSet(path, path_items, 2);
status = ProElemtreeElementGet(created_elemtree, path, &sketch_element);
status = ProElementSpecialvalueGet(sketch_element, NULL, (ProAppData *)§ion);
status = ProSectionActiveSet(section);
int *int_ids, no_of_ids, i;
status = ProSectionEntityIdsGet(section, &int_ids, &no_of_ids);
status = UserCreateLine(§ion);
status = UserSetFeatureSection(&feature, §ion);
return (status);
FUNCTION : UserSetFeatureSection()
PURPOSE : Sets the section pointer to given feature and
redefine it.
ProError UserSetFeatureSection(ProFeature* feat, ProSection *section)
ProError status;
ProElement elem_tree, elem;
ProElempath elem_path;
ProErrorlist err_list;
ProElempathItem sketch_path_item[] =
{ PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_STD_SECTION },
{ PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_SKETCHER }
status = ProFeatureElemtreeExtract(feat, NULL,PRO_FEAT_EXTRACT_NO_OPTS, &elem_tree);
status = ProElempathAlloc(&elem_path);
status = ProElempathDataSet(elem_path, sketch_path_item, 2);
status = ProElemtreeElementGet(elem_tree, elem_path, &elem);
status = ProElementSpecialvalueSet(elem, (ProAppData)*section);
status = ProElemtreeElementAdd(elem_tree, elem_path, elem);
opts[0] = PRO_FEAT_CR_NO_OPTS;
status = ProFeatureWithoptionsRedefine(NULL, feat, elem_tree, opts, PRO_REGEN_NO_FLAGS, &err_list);
return status;
FUNCTION : UserCreatePoint()
PURPOSE : Creates a section 2D Line in provided section.
ProError UserCreateLine(ProSection* section)
Pro2dLinedef line;
ProError status;
int line_id[4];
ProName section_name;
ProWSecerror section_errors1;
ProWSecerror section_errors2;
ProWSecerror section_errors3;
int n_sec;
ProMsg error_message;
char error_message_s[100];
int i, error_id;
status = ProSecerrorAlloc(§ion_errors1);
status = ProSecerrorAlloc(§ion_errors2);
status = ProSecerrorAlloc(§ion_errors3);
status = ProSection2DAlloc(section);
line.type = PRO_2D_LINE;
line.end1[0] = 0;
line.end1[1] = 0;
line.end2[0] = 100;
line.end2[1] = 0;
status = ProSectionEntityAdd(*section, (Pro2dEntdef*)&line, &line_id[0]);
line.end1[0] = 100;
line.end1[1] = 0;
line.end2[0] = 100;
line.end2[1] = 100;
status = ProSectionEntityAdd(*section, (Pro2dEntdef*)&line, &line_id[1]);
line.end1[0] = 100;
line.end1[1] = 100;
line.end2[0] = 0;
line.end2[1] = 100;
status = ProSectionEntityAdd(*section, (Pro2dEntdef*)&line, &line_id[2]);
line.end1[0] = 0;
line.end1[1] = 100;
line.end2[0] = 0;
line.end2[1] = 0;
status = ProSectionEntityAdd(*section, (Pro2dEntdef*)&line, &line_id[3]);
status = ProSectionEpsilonSet(*section, 0.1);
status = ProSectionAutodim(*section, §ion_errors1);
status = ProSecerrorCount(§ion_errors1, &n_sec);
for (i = 0; i < n_sec; i++)
status = ProSecerrorMsgGet(section_errors1, i, error_message);
ProWstringToString(error_message_s, error_message);
status = ProSecerrorItemGet(section_errors1, i, &error_id);
status = ProSectionRegenerate(*section, §ion_errors3);
status = ProSecerrorCount(§ion_errors3, &n_sec);
return (status);
