How to get session id of a model using VB API
  • May 9, 2016
  • 2319 views
Hi Mohit,
     You can get session ID by
Public AConnection As IpfcAsyncConnection
Public BSession As IpfcBaseSession
Public SessionID As String
If Not AConnection Is Nothing Then
      AConnection = CConnection.GetActiveConnection.GetConnectionId
Else
AConnection = New CCpfcAsyncConnection).Connect(Nothing, Nothing, Nothing, Nothing)
End If
SessionID = AConnection.GetConnectionId
You can access only one CREO connection via vb api, after got connection from creo you can use more than one creo session, VB API Stores the connection ID in Memory, It can only access previous CREO which already connected
mdutta1-VisitorAuthor
Hi Parthiban,
                 Thanx for your reply. but I want to get session ID of each component which is added in the model tree. using VB API
Thanx
Mohit
Hi Mohit,
    I think you're expecting Model Relation ID (i.e → ID of the components which placed in Assembly).
