I`d like to define the size of any random screw for my modelling purpose using an excel sheet. Is it possible? If yes, could anyone please explain the process of it?
What you are looking for a custom .hol files. See links below:
https://community.ptc.com/t5/3D-Part-Assembly-Design/tapped-hole-parameters/td-p/294994
https://community.ptc.com/t5/Creo-Modeling-Questions/CALLOUT-FORMAT-in-hol-files/td-p/153980
You can use the Excel information to populate the .hol files
