Hi All,
I have a model in which no default coordinate system present.
Is there any way to get or create default coordinate system(global coordinate system) using toolkit API?
There is not direct API / function to create a CSYS with Toolkit.
When you search create CSYS toolkit in the knowledge one can find this article :
https://www.ptc.com/en/support/article?n=CS221868
Basically the methodology relies on Element Tree.
in case lots of low level code is not your thing here are some options:
ProMacroLoad( L"~ Command `ProCmdDefDatumCsys`");
ProMacroExecute();
would get you default coordinate systems...
Otherwise making a UDF from default csys feature and using ProUdfCreate(...) would require less code...
Another option is to make an XML out of a default csys elemtree and to use it with ProElemtreeFromXMLCreate(...) - still less typing and code maintenance...
HIH.
FV.
To top your valid suggestions and help the questioner ponder:
Up to you to pick the appropriate solution.
An Example for the Element Tree Method:
int createACoordinateSystem_first_try = 1;
void createACoordinateSystem(ProFeature * feat) {
ProElement pro_e_feature_tree, pro_e_feature_type, pro_e_csys_method, pro_e_std_feature_name;
ProErrorlist errs;
ProError tkerr;
ProValueData value_data;
ProValue value;
ProFeatureCreateOptions opts[1];
ProName wide_string = L"";
ProModelitem p_mdl_itm;
ProSelection sel;
wcscpy_s(wide_string, PRO_NAME_SIZE, L"NAME");
ProElementAlloc(PRO_E_FEATURE_TREE, &pro_e_feature_tree);
ProElementAlloc(PRO_E_FEATURE_TYPE, &pro_e_feature_type);
value_data.type = PRO_VALUE_TYPE_INT;
value_data.v.i = PRO_FEAT_CSYS; /* 979 */
ProValueAlloc(&value);
ProValueDataSet ( value, &value_data );
ProElementValueSet ( pro_e_feature_type, value );
ProElemtreeElementAdd ( pro_e_feature_tree, NULL, pro_e_feature_type );
ProElementAlloc ( PRO_E_STD_FEATURE_NAME, &pro_e_std_feature_name );
value_data.type = PRO_VALUE_TYPE_WSTRING;
value_data.v.w = wide_string;
ProValueAlloc ( &value );
ProElementValueSet ( pro_e_std_feature_name, value );
ProElemtreeElementAdd ( pro_e_feature_tree, NULL, pro_e_std_feature_name );
ProElementAlloc(PRO_E_CSYS_METHOD, &pro_e_csys_method);
value_data.v.i = PRO_CSYS_DEFAULT;
ProElementValueSet ( pro_e_csys_method, value );
ProElemtreeElementAdd ( pro_e_feature_tree, NULL, pro_e_csys_method );
opts[0] = PRO_FEAT_CR_DEFINE_MISS_ELEMS;
tkerr = ProMdlToModelitem(addFirstKEsFeatureVisitModel, &p_mdl_itm);
tkerr = ProSelectionAlloc(NULL, &p_mdl_itm, &sel);
tkerr = ProFeatureCreate(sel, pro_e_feature_tree, opts, 1, feat, &errs);
if (tkerr != PRO_TK_NO_ERROR) {
if (createACoordinateSystem_first_try == 1) {
// Can't create the coordinate system at first
createACoordinateSystem_first_try --;
} else {
ProSelectionFree(&sel);
ProElementFree(&pro_e_feature_tree);
Br,
Eike
Eike,
Are you sure this code is valid for wildfire and creo releases?
PRO_E_CSYS_METHOD element had been obsolete for quite some time now...
Below is a feature tree for default csys (creo variety).
😀FV.
Element tree
FEATURE_TREE (COMPOUND)
|---FEATURE_TYPE VALUE (INT) = 979
|---STD_FEATURE_NAME VALUE (WSTRING) = CS1
|---CSYS_ORIGIN_CONSTRS (ARRAY)
|---CSYS_OFFSET_TYPE VALUE (INT) = 0
|---CSYS_ONSURF_TYPE VALUE (INT) = 0
|---CSYS_DIM_CONSTRS (ARRAY)
|---CSYS_ORIENTMOVES (ARRAY)
|---CSYS_NORMAL_TO_SCREEN VALUE (INT) = 0
|---CSYS_ORIENT_BY_METHOD VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS1_REF VALUE (SELECTION) =
|---CSYS_ORIENTSELAXIS1_REF_OPT VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS1_OPT VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS1_FLIP VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS2_REF VALUE (SELECTION) =
|---CSYS_ORIENTSELAXIS2_REF_OPT VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS2_OPT VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS2_FLIP VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS2_ROT_OPT VALUE (INT) = 0
|---CSYS_ORIENTSELAXIS2_ROT VALUE (DOUBLE) = 0.000000
|---CSYS_TYPE_MECH VALUE (INT) = 0
|---CSYS_FOLLOW_SRF_OPT VALUE (INT) = 0
|---CSYS_NAME_DISPLAY_OPT VALUE (INT) = 1
|---CSYS_DISPLAY_ZOOM_DEP_OPT VALUE (INT) = 0
|---CSYS_AXIS_LENGTH VALUE (DOUBLE) = 0.000000
Just copied it from some old code, tested it with a new Creo-Version but didn't update it ^.^ It works for my case but isn't secure to run.
Thanks Felkis.
Br,
Eike
Might be easier to fire off a Mapkey to get that done.
