J-Link JRE Problem with Creo2 M020?
While trying to test some J-Link apps with Creo2 M020, I
found the bundled JRE to be somewhat broken. Using a
standalone JRE with jlink_java_command, everything worked
great.
Even a simple "java -version" didn't work, which is weird
because I have found that to always work, for any java
install, PTC related or not.
Has anyone else run into this?
