J-Link JRE Problem with Creo2 M020?
MarcMettes
7-Bedrock
While trying to test some J-Link apps with Creo2 M020, I
found the bundled JRE to be somewhat broken. Using a
standalone JRE with jlink_java_command, everything worked
great.
Even a simple "java -version" didn't work, which is weird
because I have found that to always work, for any java
install, PTC related or not.
Has anyone else run into this?
Marc
Marc Mettes
I deliver with software an own JRE copy and use this to dock to the Creo. So I don't test your problem but with an own JRE it's no problem to connect to the Creo 2.0 M020 in async. mode.
I think it is a good way because many JRE versions work in different ways with the java code that I only can support some of them.
> great.
java -version works with the PTC supplied JRE with Creo 2.0 M030 and M040.
I no longer have Creo 2.0 M020 around to try it.
> Marc
> Marc Mettes
> MarcMettes@InversionConsulting.com <">mailto:MarcMettes@InversionConsulting.com>
> Visit My CAD/PDM Automation Blog
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
