JS API pfcUICommand.Designate
  • August 13, 2025
  • 2 replies
  • 3029 views
Hello, i've been tryign ot designate created command in PTC Creo JS API and didn't succed at all.
Creo API can't find message file. I've been also trying to create absolute path to message file but it didn't work too.
Here is my code example:
// 1) Get the active Creo session
var session = pfcGetCurrentSession();
// 2) Unique id for your command (make it unique per run while testing)
var COMMAND_NAME = "MyJsSampleCommand_" + (new Date().getTime());
// 3) Implement the action listener
var actionListener = pfcUICommandActionListener.create({
 OnCommand: function (commandId) {
 print("Hello from " + COMMAND_NAME + "!");
 OnCommandEnable: function (commandId) {
 return pfcCommandStatus.pfcCommandStatus_Enabled;
// 4) Create the UI command
var uiCmd = session.UICreateCommand(COMMAND_NAME, actionListener);
// 5) Designate it so it can be placed in Screen Customization
uiCmd.Designate(
 "message.txt", // Message file
 "MyCmdLabel", // Label key from ui_message.txt
 "MyCmdHelp", // Help key (or null)
 "MyCmdDesc" // Description key (or null)
// 6) (Optional) Assign an icon
// uiCmd.SetIcon("my_cmd_icon.gif");
Screenshot from support.ptc.com no directory described:
screenshot from pdf no directory described:
There is also no format and description about how does this file has to look like.
Here is how it looks like when i run it via DevTools
Best answer by ilyachaban
Message file has to be placen not into %PRO_DIRECTORY%\text but  %PRO_DIRECTORY%\text\%YOUR_LANGUAGE%
In my case it was usascii
Whole path than looked like C:\Applic\Creo_11.0.3.0\Common_Files\text\usascii
also for icon not text file but text\resource
Whole path than looked like C:\Applic\Creo_11.0.3.0\Common_Files\text\resource
RPN
18-Opal
August 13, 2025
Make sure you have properly setup your text folder, next see your message.txt file, this is referenced in your code. There are a couple of examples, but you have to deal with message id’s due to different language environments.
Tell me please where is this text folder or how can i find it
RPN
18-Opal
August 14, 2025
Here some note from the tk manual. Note: Using message.txt may dangerous 😉😵💫
ilyachaban16-PearlAuthorAnswer
