Java Application Blocked
  • July 1, 2016
  • 2 replies
  • 3931 views
Hello all,
I encoutered a problem when I opened the proToolkit help file.
The error shows as follows, does anyone know how to solve it?
Thanks in advance.
I tried to install JAVA7 ,but also failed.
jzhang-61-VisitorAuthor
Thanks for your answer.
I read these articles ,it seems the problem is solved only for Creo3.0, now I am using Creo2.0, so it seems doesn't work.
Hello, I installed
Java SE Runtime Environment 6u45 and
Java SE Development Kit 6u45
You need to configure your permissions for Java applets.
Follow the instructions from this document created by Joshua Bryant
thanks for your help.
I will give up to run the java application.
