Jlink - How to retrieve drawing into opened session
- June 17, 2014
- 1 reply
- 3282 views
how can I retrieve a drawing via jlink? I am able to retrieve a part into the session but when trying to retrieve a drawing the JRE just crashs.
if (type.equalsIgnoreCase("CADCOMPONENT")) {
ModelDescriptor descriptor = pfcModel.ModelDescriptor_Create(ModelType.MDL_PART, inputFilePath, null);
System.out.println("descriptor: " + descriptor);
descriptor.SetPath(f.getPath());
model = session.RetrieveModel(descriptor);
System.out.println(model);
} else if (type.equalsIgnoreCase("CADDRAWING")) {
ModelDescriptor descriptor = pfcModel.ModelDescriptor_Create(ModelType.MDL_DRAWING, inputFilePath, null);
System.out.println("model: " + model);
As mentioned the CADCOMPONENT is working, the drawing not.
C:\TEMP\test>java CreoConverterTest C:\TEMP\test\piston_drawing.drw CADDRAWING PDF
start
C:/Program Files/PTC/Creo 2.0/Parametric/bin/parametric.exe -g:no_graphics -i:rpc_input
Starting CREO command: C:/Program Files/PTC/Creo 2.0/Parametric/bin/parametric.exe -g:no_graphics -i:rpc_input
pm_is_portmapper_port_busy: bind failed, error = 10013
connection: com.ptc.pfc.Implementation.pfcAsyncConnection$AsyncConnection@576a9d42
session: com.ptc.pfc.Implementation.pfcSession$Session@79616c7
modelName: C:\TEMP\test\piston_drawing.drw
f: C:\TEMP\test\piston_drawing.drw
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x0000000077d4dce0, pid=8632, tid=8352
# JRE version: 6.0_35-b10
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.10-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [kernel32.dll+0xdce0]
# An error report file with more information is saved as:
# C:\TEMP\test\hs_err_pid8632.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the
I attached the full log. I hope some of you guys could guide me to the right solution.
