Linestock User Defined Parameters
  • June 24, 2024
  • 2629 views
I’m having an issue with trying to get a User defined parameter PIPE_DESCRIPTION from the linestock to the piping start part parameter DESCRIPTION.
This is so when creating a pipe solid, each pipe part will have the PIPE_DESCRIPTION parameter value added to the DESCRIPTION parameter.
Then I can bring this into my table BOM, along with all the other fittings and parts which have the same parameter.
Is this possible or is there another way?
I'm using Creo Parametric 10.0.4.0
Best answer by Barra_CSGAS
All, I thought I should post a solution (work around) I've found.
I found that I can create the same parameter name in the start part as the locked parameter from the linestock, i.e. (OD) and when using the pipe solid command, it would populate the data from the linestock to the pipe part created in the assembly.
therefore, I could create a relation using the OD to populate the DN parameter using IF statements.
because all parameters are in the start part there is no errors.
IF OD == 114.3
PIPE_DN_SIZE="DN100"
ENDIF
and Wall thickness to populate the schedule size using IF, &(AND) (only used when a duplicate WT between sizes and schedules) as well as |(OR) Statements.
/* DN50 TO DN80
IF WALL_THICKNESS == 5.54 | WALL_THICKNESS == 7.62 | WALL_THICKNESS == 8.56
PIPE_SCH="XS"
ENDIF
and having 2 different start parts, one for welded pipe, the other for seamless, and having a fixed parameter (pipe_std) for those,
I was then able to combine them together to form the required description
DESCRIPTION=STOCKNO + ", " + PIPE_DN_SIZE + ", " + PIPE_TYPE + ", " + PIPE_SCH +", " + PIPE_STD
Stockno & Pipe_type are also populated from the linestock when the pipe solid command is run.
Note:
The regenerate command needs to be run after the pipe solid command for the data to be populated.
Hope this helps
If the DESCRIPTION parameter is the one you want to use in the bill of materials, then you should address building that parameter using other information. If I were doing this I'd probably have another parameter called something like USER_DESCRIPTION which contains what you currently use for DESCRIPTION. Then add a relation of the sort
DESCRIPTION = PIPE_DESCRIPTION + ", " + USER_DESCRIPTION
I don't know how you access the PIPE_DESCRIPTION, however. Is it an accessible parameter from within your part?
thanks, Ken, for your reply,
I've tried what you have suggested the issue here is the parameters needs to be within the same component, otherwise you get an error, unless there is something I'm missing in the relations function, as I'm only new to Creo.
Below image is where I'm trying to get the PIPE_DESCRIPTION parameter, as this is a common location for all of the different pipe types and sizes.
for example, if the pipe reducers, then another linestock is associated to that pipe segment, and other pipe solid part is created from a start part.
If that start part could read the linestock parameter and populate the DESCRIPTION my problem would be solved.
I would be happy to set up a Mapkey to grab the Linestock parameter then populate the description after the pipe solid has been created, however I don't know how to extract it from the User defined tab.
I've also tried breaking up the description as you have suggested, the issue here is that each would have to be populated manually every time something I'm trying to avoid again.
Hi RPN,
Yes, I tried the relation using the feature ID and found that it could bring the required parameter from the linestock into the assembly,
however, i needed it into the Pipe Part that's created from the pipe solid command, so this doesn't do what I needed, also the feature ID changes from model to model depending on when it's added to the model so the relation will have to be change each time to suit this.
