Manually run the database server
selmaci
I would like to run database server manually. How do I manually run the database server?
I understand that C: \ Program Files \ PTC \ Creo Elements \ DirectShow Server 19.0 \ servwin \ me_dserv64_ole.exe "works in the background.
I need the parameters of this me_dserv64_ole.exe file.
I am waiting for your help in this regard.
Thanks in advance.
Sonat Elmaci
5 REPLIES 5
MaxR.Kublin
(To:selmaci)
The "Database Server" (me_dserv64_ole.exe) is running as a *Service*.
You never run this as anything else.
You need a Client (e.g. Model Manager) to access the Database - if you have a Model Manager Database.
Do you have client licenses at all?
Thank you for your answer. Yes, I have model manager license.
I got an error message when I setup Creo Elements Direct Manager Server 18 and installation is canceled.
I complete the setup with manually. I have to manually run the Software Distribution Server (apache web server).
Therefore I can not use  Job Spooler server (task manager).
If I do not choose the database server in the software setup, I use Job Spooler server successfully.
But this time I can not run the database server. Therefore I would like to run database server manually.
Or I need to run Job Spooler manually.
MaxR.Kublin
(To:selmaci)
For a Model Manager database, a Database Server, File Server and License Server are REQUIRED.
If any of the three mentioned servers (=services) is not installed and running, you can neither run a Model Manager client
nor any other additional service like Software Distribution Server, Job Server etc.
I recommend you get in touch with a consultant who has experience with a Model Manager installation.
Yes I know. For a Model Manager database, a Database Server, Software Distribution Server, File Server and License Server are REQUIRED.
The major steps for installation are as follows:
1. step is file server
2. step is  database server (I can not go to other steps because I got an error message when installing the database server. But it works.)
3. step is services(Web services, task agent) but I can not come this step because I got an error message when installing the database server and installation is cancel.
And finally software distribution server (apache web server) I run it manually with this parameter. httpd.exe -k install
In this case, the web services, task agent are not running. Can I run the background (as service) using a parameter to run the web services, task agent?
MaxR.Kublin
(To:selmaci)
As said already.
Unless File Server and Database Server are not installed and running, no other step makes sense.
The Apache is the so-called "SDS = Software Distribution Server" - but running that does also not make any sense,
when you do not have a Database to connect to.
Will stop providing consulting for free now.
Please get in touch with PTC Support or a Consulting Company.
    Max
