Outdated mass properties
  • October 23, 2024
  • 3 replies
  • 2786 views
Hello, I received a message in German saying that the mass properties are outdated.
In subsequent processes, I always receive a similar message.
Can someone explain how to fix this?
Is it possible that some configuration has changed and can no longer be used?
I dont want just to hide the notification.
The Startparts are created in Creo 10.0.3.0 and am still using it.
I activated the mass_property_calculate and changed but its not solving the issue.
Best answer by MartinHanak
please read https://www.ptc.com/en/support/article/CS256878 document.
If you can upload your model I will be able to investigate it.
did you set mass_property_calculate AUTOMATIC ?
Can you upload some problematic part?
thank you for the answer.
Yes, I did, but now I am getting the Message (translated from German):
The modelscene contains a roomenvironment, that is no longer supported. For this reason, Creo has updated the scene to a supported environment. The model must be save again, to avoid this message in the future.
I have saved the empty model and opened it again as template. It's not working. I am still getting the Message about the Environment.
Their solution did half-work on my issue. Now I am getting a different notification (translated from German):
Catalina
Community Moderator
October 28, 2024
Hi @OS_11014878,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Moderator
