ProSelect Dialog issue. it can not be top.
ProSelect dialog goes back , can not be top.
User can not check ProSelect processing is stopped. (if ProSelect dialog was hidden status.)
so we try to make ProSelect dialog position in top.
1. using timer callback function.
2. using ProSelectionPostSelact Funtion.
method 1 is worried about performance about timer func and creo work.
method 2 is not work if select item is not matching filter.
if you guys have good idea, please help us.
thank you.
