(ProToolkit, Creo 2.0) How to tessellate a part w.r.t. assembly features?
in my C++ code, I already successfully traverse through assemblies and tessellate the geometries of parts.
How can I tessellate parts inside an assembly with respect to assembly features which have an impact to the triangle mesh of that part?
The function, I'm using for tesselation is: ProPartTessellate(). I just call this function for each part and only get the part's original tiangle mesh.
The screenshot below is an example of an assembly with some profiles as parts. One of the profiles contains a hole. This hole is an assembly feature (as you can see in the model tree view):
