Redrawing the screen when editing annotations in drafting on a low-spec PC
  • November 20, 2023
  • 1616 views
When you try to edit annotation text etc. in drafting, it is redrawn continuously, making it very difficult to use.
I would like to know if there is a way to prevent continuous redrawing using config etc.
this is caused by graphic card driver.
What graphic card is installed in your PC ?
What graphic card driver version is installed ?
Hi Martin
Thank you for your quick reply.
I am using the following drivers.
Best regards.
download older/newer versions of driver, install it and test. Only this way you can resolve your problem.
Note: PTC does not support Intel graphic cards.
