Scissor Lift - Kinematics - And other questions
- October 6, 2013
- 4 replies
- 3005 views
I am a mentor to FTC team and trying to learn Creo in order to help them use it. Attempting to build a scissor lift with kinematics but having some issues.
I created an AxleSet subassembly using the following parts:
TETRIX_739088_2012.PRT - Axle
TETRIX_739092_2012.ASM - Axle Collar (2 of them)
TETRIX_739091_2012.PRT - Bushing (4 of them)
The parts are set up such that a C Channel (32 mm width) can fit between the bushing and the collars on the outside to lock them in place.
I then created another assembly call ScissorArm that starts with the AxleSet and I then a C channel is added (TETRIX_739068_2012.PRT). The AxleSet is in the first hole of the C channel and C channel fits perfectly between 2 of the four bushings.
I then create a new assemble called the ScissorLift. I start with a single hole C channel (TETRIX_73905_2012.PRT) and then I add the ScissorArm with a Pin connection using the axle of the ScissorArm with the C channel hole and the a bushing coincident with the signle hole C channel so that it fits between the other two bushings. Then try to drag the long C channel expecting it to rotate. It does kind rotate but the entire structure moves around. I would of expected the single whole C channel to sit place and the long C channel to "rotate" like a gear. What am I doing wrong?
Other minor questions, when an assembly gets large and you add new part it goes to some default location. How do I get it to go where I am view/working? I keep having to view out and then move part to the area I am at.
How do I get CREO to use the same working directory when I exit and come back?
Creo seems to like to have all the parts and assembly in the same directory. But I would like to keep the kit of parts in a separate directory than my model, but when I re-open it doesn't find the parts and have to re-tell it where the parts are.
