Tutorial on driving Creo through a PoSh shell
Thought I'd give back a bit to the community, one secret weapon that I've been leveraging for quick and dirty automation is to access the asynchronous VB API through PowerShell. VB API is a .NET construct, so it's accessible through VB, C#, as well as PowerShell. API wise, it is almost 1:1 with the base J-Link package, so you are not missing out on much. You will not have Toolkit functionality, but you can in theory create Toolkit DLLs to load in via config.pro that you can invoke via the VB API.
The convenience of using PowerShell is that it is deployed by default on all machines Win7+. You may run into some compatibility issues with Powershell V2, since that was a rather primitive version compared to what we have today. Win10 deploys with Powershell 5 and above.
It is also a shell environment. You do not need to compile anything or open any special program, you can literally link up in a new shell window and immediately start piloting Creo.
So far I can pretty much create a quick one off script on a network drive, point a user to it, and immediately have them running my automation.
To link up, you must ensure you have the VB API installed with Creo.
I'll refer to the loadpoint of Creo Parametric from here on out as PRO_DIRECTORY. This is, for example,
gci HKLM:\Software\Classes -ea 0| ? {$_.PSChildName -match '^\w+\.\w+$' -and
(gp "$($_.PSPath)\CLSID" -ea 0)} | ft PSChildName
# Get path of running Creo executable
$proc = Get-Process | Where-Object {$_.ProcessName -eq "xtop"}
if ($proc -eq $null) {
Write-Output "Running Creo process (xtop) not found"
Write-Output "Press any key to continue..."
Read-Host
exit
$pc_path = $proc.Path -replace "xtop.exe", "pro_comm_msg.exe"
$Env:PRO_DIRECTORY = $proc.Path.TrimEnd("xtop.exe")
$Env:PRO_COMM_MSG_EXE = $pc_path
# Check if VB API is registered.
try {
$testasync = New-Object -ComObject pfcls.pfcAsyncConnection
catch {
Write-Output "VB API not yet registered on this machine, performing first time setup..."
$vb_path = $proc.Path -replace "Common Files(.*)$", "Parametric\bin\vb_api_register.bat"
Start-Process -Wait -FilePath $vb_path
# Initiate connection to Creo.
try {
$async = New-Object -ComObject pfcls.pfcAsyncConnection
$connection = $async.Connect($null, $null, $null, $null)
$session = $connection.Session
catch {
$_
Write-Output "Could not connect to Creo session."
Read-Host
exit
$session.GetActiveModel()
$session.RunMacro('~ Command `ProCmdRibbonOptionsDlg` ')
$connection.Disconnect($null)
