VB Api program convert from .NET framework to .NET 5.0
  • November 19, 2021
  • 2757 views
I wanted to upgrade my VB.NET program from framework to .NET 5.0
After upgrading with the converter from Microsoft I have the problem, that some classes are not casted correct.
For example I get error: Public member 'CurrentModel' on type 'IDpfcSession' not found
for line: ...asyncConnection.Session.CurrentModel
Does anybody has a solution?
Thank you!
Did you mean that you want to update the program from VB.NET to C# .NET 5.0 ?
Or just update version .NET libraries?
i want to upgrade from VB .NET framework 4.X to VB .NET 5.0(6.0) if it works.
A switch to C# is planned on the long run, but not at the moment
Did you switch to new Creo Parametric version? What Creo version did you using now?
Maybe, need to Registering the new COM Server and referencing to new COM library in VS.
