by How to map 2D section created edges to original edges using toolkit
  • January 11, 2021
  • 0 replies
  • 1258 views
We want to know a way to map cross section edges which are created internally by Creo with the original model edges so that we can co-relate attachment information of dimensions attached to such internal edges in Creo through Toolkit.
in other words, dimensions in drawing is attached to internal edges of cross section. So, we are not able to identify which feature's dimension it is.... Is there a way to map cross section edges and feature edges?
There is no direct API for this, but we need to have this mapping. Just wanted to know is there any mapping by some work around is possible on this?
