create/edit feat param in assembly
- December 29, 2022
- 1 reply
- 1909 views
by using proselection i can able to create component/feat parameters in assembly
but when i try to create a parameter instead of selection it will create either part or assembly level parameter.
Is there any option to create or edit Feat_Param in a component level in assembly.
///*****************WHILE USING BELOW CODE IT CREATES CORRECTLY****************************////////////////////
err = ProSelect("component", 1, NULL, NULL, NULL, NULL, &p_sel_array, &p_n_sels);
err = ProSelectionModelitemGet(*p_sel_array, &p_mdlitem);
err = ProParamvalueSet(&new_value, (void*)L"FIND_NUMBER", PRO_PARAM_STRING);
err = ProParameterCreate(&p_mdlitem, L"6", &new_value, &new_param);
instead of selection i need all components list in the assembly
/////*****************below code update parameter as assembly level********************//////////////////
status = ProDwgtableCellRefmodelGet(&table[0], 2, i, &proAssemblyRepeatRg, &proMdlRepeatRg);
ProMdlToModelitem(proAssemblyRepeatRg, &p_mdlitem);
/////*****************below code update parameter as part level********************//////////////////
ProMdlToModelitem(proMdlRepeatRg, &p_mdlitem);
