error LNK2019: unresolved external symbol _ProMenubarmenuPushbuttonAdd referenced in function _user_initialize
  • May 19, 2011
  • 2822 views
main.obj : error LNK2019: unresolved external symbol _ProMenubarmenuPushbuttonAdd referenced in function _user_initialize
I have a problem with my 64-bit release of ProE 5.0 (protoolkit\x86e_win64 and prodevelop\x86e_win64 files). I can’t link my project on Windows XP 64-bit and Visual Studio 2008. I can see all needs ProE’s files inside obj directories (I mean LIB files) but the files seem to don’t include proper functions. I built the same project on 32-bit machine without any problems....strange.
Regards Andrzej.
Cut a long story short:
This preprocessor parameter caused the problems _X86_=1. This parameter WIN32 could be change too.
If you use Visual Studio 2005 to compile you project, you will need Microsoft HOT FIX because all lib files from PTC 5.0 was created in Visual Studio 2008.
http://support.microsoft.com/kb/949009/
Probably you need replace file wsock32.lib to netapi32.lib file in your configuration Linker->Input configuration.
Thank a lot Andrzej for myself answer.
