18-Opal
July 12, 2018
is it possible a creaet Drawing with toolikt?
  • July 12, 2018
  • 2811 views
Hi
is it possible to creaet a Drawing with toolkit?
if select a specific model, we get model name using ProMdlNameGet.
and model name will be fill a New Drawing File name.
and call dialog following picture.
is it possible?
and can toolkit call a update sheets?
thanks
Best answer by Ketan_Lalcheta
Below is list of API:
  • ProDrawingFromTmpltCreate() to create drawing from template
  • ProDwgSheetRegenerate() for sheet update. Make sure you set all drawing sheet as current sheet one by one before calling API ProDwgSheetRegenerate().
- HIH
Ketan
- HIH
Ketan
CHASEONHO18-OpalAuthor
18-Opal
July 17, 2018
Thank you!
also you can call new drawing dialog with using ProMacroLoad()
Yes...But I personally dont prefer macro. I try to avoid it as much as possible.
