j-link JDK
joe_c
j-link JDK
Folks
I cant seem to run index.html and API wizard  in jlink or weblink.  The idle error: Testing for existing Java Foundation Classes (swing). Please wait...
I have downloaded the latest java JDK 8 update 91 which comes with JRE.  But then i read that PTC supports 1.4.1 only
Has anyone run into the same?
joe
5 REPLIES 5
Hi Jose,
     which browser you are using?
It's not working for me in google chrome & working fine with Internet explorer V9.
also I Installed jdk1.7 & jre 7.
Check Your Internet explorer
Tools → Manage Addon. (Check highlighted add on available)
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
joe_c
(To:PARTHIBAN_K)
Hi Parthiban
This is what i have in IE11.  I am missing the Java Plug-in..  I thought it would download automatically with the JDK kit 1.8.0_91 (64 bit)
I keep getting this error when opening index.html and API wizard
thanks a lot..
Hi Jose,
    jdk 1.8 only not enough, you also need to install jre7 or above version.
Java Runtime Environment (JRE) : It is virtural machine inwhich your java application can run. JRE containts plug-in for browser to execute java applets.
j-link index.html run as java applet, so you must install JRE also
Java Development Kit (JDK) : It use to develop java applications, simply it is a compiler. JDK includes JRE.
My assumption is it will work when you seperately install JRE also, just try this method also
Parthiban Kannan
joe_c
(To:PARTHIBAN_K)
Parthi
The JDK installs the JRE but nevertheless I downloaded the jre-8u91-windows-x64.exe instead of the tar,gz file.  I still cant get it to run. It looks the same as it did before.
I wonder if I should  try a lower version of java. I am in Windows 10..  Or should install netbeans or eclipse.. Will that download the plugin?
